Old 10-21-2020, 03:27 PM
Burd's Avatar
Burd Burd is offline
Default 4-15” steel wheels
Here’s 4 clean steel wheels, no rust, 15”. $200 for the set of 4. Pick up in the D.
Black on back side, gold on front.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Attachments - The Supercar Registry AE1D2865-44A3-4DF4-8448-C6EA36223396.jpg 7EB510CC-A053-402C-AF48-45C2BD60C4B1.jpg 30BDB9CC-8444-43EE-9F05-6F8D30CFBCF2.jpg
Old 10-22-2020, 02:33 PM
Burd's Avatar
I’ll include the lug nuts as well.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 10-22-2020, 04:38 PM
RobR RobR is offline
How wide are they? TIA
Old 10-22-2020, 11:48 PM
Burd's Avatar
They measure 8” across.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 10-23-2020, 12:54 PM
Burd's Avatar
Do you want me to look for wheel codes, I got these back in the 90’s, they were re-cond old wheels. They were already blasted and painted black. The tire shop I got them at is long out of buss.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 10-25-2020, 10:46 PM
Burd's Avatar
Still available
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 10-26-2020, 12:01 PM
Are they unmounted? If so., the size should be easily seen/stamped.
15x7 or 15x8 JJ or JK or whatever
Be nice to see the actual wheels spread out without tires on them if being sold that way
M
Old 10-27-2020, 02:53 PM
Burd's Avatar
Yes. Un mounted. Pic is just to show a dog dish on them.
Mysterychevelle, I can text you more pics if you need any. Here’s 2. They all look the same, no pitting no rust.
I doubt it being a matched set, I bought these from JRE tire here in Detroit area, they are long out of buss, they were gm wheels that were refur’b. ( blasted and painted black. Steel wheels are hard to find, at least in the D.
If someone needs a clean set that the car isn’t going to pebble beach, this is a nice set.
I’ll throw in the lugs nut I bought fir them too.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 10-27-2020, 03:20 PM
Burd's Avatar
Other 2, I didn’t use trim rings, so the rims aren’t all scratched up from trim rings.
Being a non matched set, I’m not worrying about the codes. When you put a dog dish hub cap on, they all 4 look the same.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 10-28-2020, 03:28 PM
Stefano Stefano is offline
Can you measure the offset?
