Old 02-05-2021, 08:46 PM
RALLY RALLY is online now
Default 1969 327 Std Bore Block
Used 1969 327 Block. This is not a complete 327 engine. Block only. Block cast number 3959512. Cast Date B-27-9. Pad Stamped 0411FC. According to a retired well known GM source i contacted the 9512 block only had one production application 69 passenger 327 2-barrel automatic but it was used for many years as a primary Service replacement and CE 5/50 warranty block for 4 inch bore applications. 2 bolt Block. It was the last block that was cast with the crankcase vent tube hole at the back and was machined in both small journal and large journal configurations. Restorers like the 512 block as they can have a proper functional and correct PCV system and still use the early factory finned aluminum valve covers without holes. Block is Std- Bore Large Journal.Good block for a nice street car or racing application. Good 327 blocks are getting hard to find. I do not have any other 327 parts for this Block. 200.00 dollars buys it. Will not deliver or ship. Block will have to be picked up by you. Block is located in Mich, 2 hours north of the Indiana Border. Send me a message for more details and location. Need to move this block.
