Old 03-23-2021, 03:10 PM
chris slawski chris slawski is offline
Default 1969 Camaro SS 396 L78
Yes this was listed prior...new LOWER price, and package broken apart.
Up for sale
1969 Camaro L78 4 speed
****Please read ENTIRE ad****
California built car
Fathom green black gut
NO X Code
This car had front harness in the trunk, no brake lines or fuel lines original engine and trans were LONG gone.
Based on my research through both Yenko.net, and the Camaros.org web site this is what I know 100%
Factory power disc brakes are still on the car booster and calipers
Original big block heater core is still in the car
Original 4 speed big block cross member is still in the car
The original fuel tank has 1 line and it is 3/8 inch diameter, I had to drop the tank to find out.
The original dual exhaust brackets are still on the car
When I sanded some of the blue house paint off the tail panel it is black….NOT fathom green
The car still wears it’s original side gills, well on is still on the other is off the car
Consol with gauges
Gauge cluster with clock and correct L78 6k 7k tach
***Please note the tach gauge cluster is NOT in the car, it is in a seperate box for safe keeping***
Condition of metal overall GOOD
Drop offs are good not perfect but repairable
Does need full trunk pan has hole for a sump (?) and prior fiberglass in well
Original doors are very nice and have never been off the car
Rockers are excellent
Floor is very good but trans tunnel was hacked
Package tray good but cut for speakers
Rear deck filler is shot
Front fenders have rot at bottom but straight
Hood is good but not sure what may or may not be under the paint
The interior is complete
Seats are in very good shape, driver seat has a split on window side seam otherwise very good
Headiner has a cut so needs replacement
Have full set of original standard seatbelts
Kick panels are in good shape, not cut for speakers
The front glass is a new replacement, the rest are all very good and original to the car
All window internals are present and operational
Have all trim and moldings including NOS rocker trim
All AMK hardware kits for engine, interior, body and chassis
The wheels and tires pictured go with the car…they are NOT dated, or coded correctly, but roll very nice and hold air.
NOW FOR THE GOOD PART!!!!
Correct original engine frame mounts
New repo chambered exhaust in box with hangers
All new brake and fuel lines in box with ORIGINAL clips in box from In Line Tube
New fuel tank, sending unit, and harness
Original CORRECT radiator (needs core)
12 bolt rear
Included in the sale are the following AMD replacement panels
Full trunk pan
Rear deck filler
Rear package tray
Classic Industries Trunk gutters
My Name is Chris
Ebay handle Gozling1 if you want to look at seller feedback
Cell number is 609-605-5368 until 9 pm please…I am old…and fat.
I cannot deal with a transport company to help load, too many bad experiences, also you are going to need a 2nd truck for all the parts.
I can help you push into your enclosed flat floor car trailer
$19750.00
Chris Slawski
69 Nova
69 Malibu
69 Camaro RS
69 Camaro SS 396
Attachments - The Supercar Registry 20201108_151843.jpg 20201108_151804.jpg 20201108_151721.jpg 20200204_144003.jpg
