Old 07-29-2021, 08:58 PM
X66 714's Avatar
X66 714 X66 714 is online now
Default 1969 Camaro tilt horn contact
My 1969 Camaro has tilt column & the horn has never worked since the day I bought it in 1981. The car has the correct cancel cam which is special. I'm using the standard 1969 steering wheel. It has a spring & a pin for the horn contact. Does the spring go in first or the pin? What holds the 2 wires & retainer to the cancel cam? Thank you, Joe
Old 07-29-2021, 10:37 PM
jl8z28 jl8z28 is offline
Spring goes first
The Following User Says Thank You to jl8z28 For This Useful Post:
X66 714 (07-29-2021)
Old 07-29-2021, 11:19 PM
X66 714's Avatar
Thank you. Now I just need to find out what hold the small loom from the horn button to the cancel cam. Thank you, Joe
