Old 08-28-2021, 04:31 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Default 1969 ONLY 427 396 BB Big Block PS power steering PUMP and alternator brackets
Hi Gang, rare package deal here. 1969 ONLY parts.
recent take off alternator brackets & PS pump and brackets. Appears to be off a recently running engine too - maybe a casualty of an LS swap... no idea.
As shown, I'm certain that this is a passenger car pump housing (thanks for the tutorial Warren!) as the non pressure side line does face backwards, but has multiple bends indicating it's not assembly line for Camaro Nova Chevelle but would likely fit - it even appears that it's been tweaked a bit to perhaps fit one of those. Likely a Caprice or Impala assembly line piece.
Anyway, still a desirable factory assembly line set up here; includes all hardware as shown that was found with the group.
VERY restorable pieces or use as-is for an original or even patina type survivor.
Includes:
the alternator - no hole - upper bracket with heater hose bracket.
correct lower DSP flat no smog spacer bracket.
most importantly the correct W stamped head long bolt
correct spacer
AB stamped original support bracket
front intake engine lift bracket (no rear flat bracket) and 2 intake bolts
various hardware with original head marking
PS power steering pump (spins freely but should be considered a core)
1969 427 or 396 housing / reservoir as described above with lid
all 3 correct 1969 ONLY PS brackets and hardware with correct maker marks including FABCO on the cradle
All very clean pieces, greasy and as recently found.
LOTS of photos below for full picture, pun intended.
Will be separated / un bolted further to fit in a box and packed smartly.
$850 PPFF shipped & fully insured to the US
Cheers all,
Anthony
Attachments - The Supercar Registry IMG_5920.jpg IMG_5919.jpg IMG_5918.jpg IMG_5917.jpg
