Old 04-19-2022, 12:34 AM
scuncio scuncio is offline
Default Thrust button for hydraulic roller - stock appearing
Hi folks,
I am building a somewhat stock appearing SBC with a hydraulic roller. Has anyone had any luck getting a factory stamped timing cover to work?
Thanks!
Old 04-19-2022, 01:39 AM
Both my roller cam motors have stock timing covers.
No issues with either one.
Old 04-19-2022, 02:10 AM
x33rs x33rs is offline
I use the stock timing covers on both SBC's and BBC's here with rollers. Works fine. As long as end play is where it needs to be, all good.
Old 04-19-2022, 02:13 AM
Great. Which timing set and button type are you using?
Old 04-19-2022, 09:35 AM
I made a bracket that bolts to the back of the water pump with a preload bolt that pushes against the timing cover to set end play and support the cover.
