Old 01-21-2024, 10:42 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Default cheap 772 fan - dated B70
Hi Gang, as the title says, a cheap alternative to the often expensive 772 fan.
It's a Genuine 3947772 fan, and a nice date of B70 but I believe it was in a wreck - one blade is pretty bent and another has a shaved edge / lip - a few others are tweaked slightly too, all as shown. Tip bent over, nick out of the end, that kind of thing. The damage appears as if inflicted while it was spinning, so...
Anyway, here's a real 772 fan for a driver or flipper - it's got the look, and the date and and will just need a little clean up and straightening which is likely not a big deal for most here reading this. I spun it on a loose water pump and it's within enough tolerance I believe; just that one blade that's the most glaring.
70.00 plus the actual shipping.
Lots of photos below for the whole picture. If you want this date, here's an option.
Cheers all,
Anthony
Attachments - The Supercar Registry IMG_7350.jpg IMG_7349.jpg IMG_7348.jpg IMG_7347.jpg
