Old 03-07-2002, 03:07 AM
Tommy Tommy is offline
Default 68 nova interior question
does anyone have or used to have a 68 Chevy II with the 737 (dark blue vinyl with cloth) trim code? Mine has been covered a couple of times and I can't find a picture or donor car to look at to see if I know exactly what It should look like. I have found an original bolt of the fabric used for the inserts but am not sure if the standard bench and the deluxe bench setup were stitched in the same way (one may have used more vinyl than the other)If anyone has a pic or knows for sure let me know, the guy that is rebuilding my seats says on the standard interior the cloth would go all the way across and the deluxe would have breaks on each side and the middle for blue madrid vinyl. Thnks in advance. Tommy
Old 03-07-2002, 09:35 PM
sixtiesmuscle sixtiesmuscle is offline
Default Re: 68 nova interior question
Try looking in a brochure with all the models in it. That usually will show the various interiors.
Old 03-07-2002, 11:32 PM
thanks, I have looked in one brochure but it only showed a four door with the blue cloth. I remembered I had seen a junked 68 in Linden,TN with A cloth bench so I went back today and took a few pics of the seats. It was the same as mine except 741(gold) instead of737(blue). Should be no problem now, Thanks again.
Old 03-08-2002, 12:19 AM
Stefano Stefano is offline
I have a freind who has a Blue/Blue 1970
L-78 Nova, unrestored and very original that has the Blue cloth Bench.
I do not know if the cloth would be similar? Just trying to help.
Old 03-08-2002, 02:52 AM
68 COPO II 68 COPO II is offline
They were both stitched the same way with a 6-8 inch vinyl strip down the middle. I will scan and send you picturs of both.
Old 03-08-2002, 03:26 AM
The interior I looked at today was a standard interior and still had the clear plastic over the seats and was striped cloth across the entire length of the front and rear seats and had vinyl on the upper portion and sides and complete back side of front bench. This car has been sitting probably 20 years or more and was shot to say the least but looked untouched except what the sun and mice had a hand in. I think the deluxe interior had the vinyl in the center sections and had a cloth piece on the back side of the front bench and was a different fabric than the standard cars got. the guy starting the work wants to install the fabric on the back of the bench but I think it should be vinyl?? The pictures would be a great help. I want to make sure I get it right. Thanks again.
Old 03-08-2002, 04:24 AM
bbdon bbdon is offline
It should look like this. The blue cloth has little dots instead of the triangle pattern though. http://www.classicnovas.net/brochure/68-7.htm
Old 03-08-2002, 09:12 AM
Thanks for ther pics bbdon. Those were the same pics I was sending. The gold was described as custom and the blue interior was standard.
Old 03-08-2002, 10:35 PM
Thanks for the pics. the gold was a custom and the blue in that brochure was on a four door. I really don't think my standard interior should have the vinyl strip in the center section between the splits since the two in boneyards didn't. I really need to see a 737 code 2 door to be sure. I have about a month before They start work on mine so If anyone knows for sure let me know. Thanks again.
Old 03-09-2002, 12:31 PM
I don't know if this will help,but I collect Chevrolet Dealership Displays.I have the Paint and Fabric boards from 1969-72.The code 737 shows a swatch of light blue vinyl.no fabric.
