What is the difference between a 2 bolt and 4 bolt main? How do they perform different from each other? I have heard that 2 bolts are not a good engine. All opinions are deeply appreciated. Thanks
Rob |
probally not any performance difference just stronger. have built and run both and also have run and blown up both. hope that helps
20 foot 75 hp good time at the lake |
A 2 bolt main has only 2 bolts per main cap, and a 4 bolt main has 4 bolt per main cap.
Bout a thousand $$ in places---more if it is the right 4 bolt. Some controversy on the 2 vs 4 bolt blocks. The caps are larger on the 2 bolt so some say they are stronger, but 4 bolts have.....well 4 bolts.
If the caps are tight in the block, running a cross drilled crank, and a straight bore....I don't know how you hurt a bottom end in a Big Block Chevrolet if it is put together right!! |
about 15 years ago a racer I knew ran in the 10's in his 66 chevelle with a 2 bolt chev block and 3/8's rods. I'm sure the engine was put together well though.
