Old 01-27-2003, 03:45 AM
jaze70ss jaze70ss is offline
Default Suspension colors?
My 70 is in the suspension detail stage and i have seen rear end housings painted chassis black and dark gray what is the actual color of the major parts?? any help would be greatly appreciated
thanks
joe bacon
70 l34
67 427
Old 01-27-2003, 04:11 AM
SS427's Avatar
SS427 SS427 is offline
Default Re: Suspension colors?
Joe,
My research shows that the rear ends were painted as an assembly with the backing plates and drums installed. On some survivor cars I have seen, some drums were painted almost entirely black while others had overspray around the back edge. The backing plates were natural on the inside. I believe the lines and junction block were installed after they were painted.
On '70 Chevelles, most rearends were painted with the exception of Van Nuys cars. I have seen many of these with an all natural (not gray painted) rearends. JMO
Rick
Rick Nelson
Old 01-28-2003, 02:03 PM
My Fremont 66 SS has all natural rear, had no black other than dirt and grime pre-resto., but that may only go to the Calif. aspect...no rush to undercoat and wasn't on the dealer lot but a day or so.
Mike
Old 01-28-2003, 03:49 PM
YENKO DEUCE REGISTRY's Avatar
Mike;
What's the number on your diff. cover represent?
Marlin
Old 01-28-2003, 07:35 PM
Not seen very well in that particular photo, but it is Actually a factory tracking/sequence number...it is also on my TRIM TAG...it was a "partial" seen and replicated at time of resto.
MC
Old 01-28-2003, 07:41 PM
Interesting, I was curious because I found a big, yellow crayon '36' written under the center section of the rear on my car, and a white 'x' by the pinion yoke. The Novas received a frame sequence number written in white on the engine cradle, it also corresponds to the the broadcast sheet per NNN.
Thx,
Marlin
Old 01-27-2003, 05:00 PM
RonNova396L34 RonNova396L34 is offline
jaze70ss
You may want to refer to this thread.
https://www.yenko.net/ubbthreads/show...o=&fpart=1
Ron [img]/ubbthreads/images/icons/grin.gif[/img]
Old 01-27-2003, 09:36 PM
Many thanks for the insight!!! since my car is an Arlington ss it looks like it gets some semi gloss....
best regards,
jaze70ss
70 l34
67 427
