Old 05-23-2003, 05:38 AM
Peter D Peter D is offline
Default z28 intake ouestions
1969 z-28 question #1. waterneck lower driver side corner has a thin triangle cast into it with a 1/16 (approximantly) inch hole. Is this a stock water neck or something oddball? If it is stock, what is the hole for? #2 the intake manifold (same car) has a 1 1/4 freeze plug in the place where earlier (pre-smog)manifolds had a riser to add oil. Is this manifold period correct or a bogie? As always thanks in advance. Dazed and confuesed [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/dunno.gif[/img] [img]/ubbthreads/images/graemlins/[/img]
Old 05-23-2003, 05:47 AM
68z302 68z302 is offline
Default Re: z28 intake ouestions
Not sure about the hole in the waterneck, but it's probably for a return spring? The plug for the oil filler is correct for '69.
If you posted the cast in part number on the intake it would be easier to ID [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 05-23-2003, 11:34 AM
SS427's Avatar
SS427 SS427 is offline
The 660 water neck is correct and the little tab is in fact for the carb return spring depending on useage. This neck was used on many different applications.
Rick
Rick Nelson
Old 05-29-2003, 04:08 AM
ss427, That was my guess on the waterneck hole thank you for confirming it. 682302 thank you on the freez-plug confirmation and the part # on the manifold is 1843657 and I can't read the last number but it looks like a 2........ [img]/ubbthreads/images/graemlins/dunno.gif[/img]...... [img]/ubbthreads/images/graemlins/tongue.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]... O.K. Yuck Yuck the cast # is 3932472 the manifold also has a snowflake with a W in the center on the driver side front. lemeknow and thank you in advance. Peter [img]/ubbthreads/images/graemlins/beers.gif[/img] [img]/ubbthreads/images/graemlins/flag.gif[/img]
Old 06-01-2003, 05:53 AM
Yup,
You got a manifold for a '69 z28 [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Rob
