I am currently helping a buddy of mine rebuild his engine from a 69 Camaro. I have located the engine code numbers on the engine pad with no problem. They read VO8I4FL, which tells me that this car should have a Turbo 350 behind it, which it does.
Unfortunatley this car was built past the midway point for 69 Camaro's, when they moved the alternator from the drivers side to the passenger side. In doing this, they had to move the vin# from the engine pad to the rough casting located by the oil filer, so they could stamp it. This is all dandy, except that I can in no way read the numbers stamped on that rough casting. Has anyone had this problem, and if so, is there any easy way to get these numbers. Just because the engine code says that this engine belongs in front of a Turbo 350, doesn't mean that it is the orginal engine for this car. It could have been in another vehicle with a Turbo 350. Aside from 69 Camaro's, where there any other Chevrolet models that had this FL engine code? Just want to make sure before I tear this engine down for him that the Vin # on the engine matches the vin on the car. Any advice? [img]/ubbthreads/images/graemlins/flag.gif[/img]
Tony |
