Old 09-11-2004, 08:36 PM
69LM1's Avatar
69LM1 69LM1 is offline
Default BB flywheel same as SB??????
Hi,
This may seem like a newbie question, but is the flywheel from a SB manual the same as a BB manual?
I am dropping that 402 into a camaro that was a 350/muncie 4spd (it was not matching # previous)and we were not sure if we need to get another flywheel!
Thanks for any help!
Rich
Rich Pern
69 Camaro COPO "Tin Soldier"
Old 09-13-2004, 06:39 AM
NCGuy68 NCGuy68 is offline
Default Re: BB flywheel same as SB??????
Rich,
For original applications, the small blocks used a 10.5" clutch and the big blocks used a 11.0" clutch. The flywheels as well as the bellhousings are specific to each for manual tranns.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 09-13-2004, 07:21 AM
Pantera Pantera is offline
I am not sure but I want to say No they are not quite the same. The bolt pattern on a SB is the same as a BB but you can't use it on a BB. Seemes to me that A big block uses a external balance weight which is built on the BB flywheel. Been quite a while since I built one but that sticks in my mind.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 09-13-2004, 10:46 PM
YENKO DEUCE REGISTRY's Avatar
They are the same except for the 454 version which is externally balanced.
Not all small blocks used the 10.5", nor did the all the big blocks use the 11.0". The '69 Z28 used the 10.5" whereas the '70 Z28's used the 11.0". I believe the L88's used the 10.5" as well.
Marlin
Old 09-13-2004, 11:22 PM
BARN FIND BARN FIND is offline
I have had both flywheels in my SB Camaro and never had to change the bellhousing.
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 09-13-2004, 11:23 PM
Marlin, I believe you are correct in all accounts.
