Old 10-26-2004, 10:01 PM
YENKO DEUCE REGISTRY's Avatar
Default VIN on an a/t trans
Where is the VIN # located on an a/t trans from 1968-1972?
Marlin
Old 10-26-2004, 10:08 PM
DaJudge DaJudge is offline
Default Re: VIN on an a/t trans
Hope this helps
On the THM350, the VIN will be stamped on either the drivers side housing near the shifter, on the right side of the housing just above the pan, or on a boss behind the bellhousing flange on the passenger side of the transmission.
On the THM400 the VIN is stamped on a machined surface just above the pan on the drivers side.
Mike
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span>
Old 10-26-2004, 10:46 PM
To add to what Mike said,on the TH400,that machined pad is behind/beneath the rubber boot that protects the shifter linkage.Usually the lead pipe is parallel to it,so you have to get behind it to notice it.
Old 10-26-2004, 11:17 PM
That's what we were thinking, but it's not there on Tommy K's new Deuce. However, it is stamped on the passenger side bellhousing flange above the dust cover! It's very light, but it's all there. The date code is exactly the same - to the day - as other a/t deuces. We have'nt had the opportunity to see where the VIN # was stamped until today.
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 10-27-2004, 02:16 AM
bkhpah bkhpah is offline
On the 69 CX it is located directly behind the starter motor on the flange that the dust cover bolts to. The VIN is very light. From my conversations with Tommy K today his is in the same area on the 70 car..BKH
Old 10-27-2004, 03:53 PM
Exactly
Looks like the Willow Run boys stamped them in a different location, 'cause we were all over the driver's side of that thing on Sunday afternoon and couldn't find it!
Marlin
