Old 03-09-2005, 02:46 AM
ls6crate ls6crate is offline
Default 70 chevelle fuel lines
boy i love this place.my question is on my 70 chevelle i just noticed (i recently bought this car) that i have two fuel lines on the passenger side frame. do all SS's have a return line or did only certain engines have them? i havenet traced them to the tank yet, do they go into the top of the tank? i'm asking because when i was checking my axle codes i noticed two lines comming out of the side of the tank on the passenger side that were blocked off. at least i think they were comming out of the tank, i didn't check real close. another question, my air cond. system unit was removed and in the opening behind the valve cover, on the firewall,is a stamped steel cover over the opening, and there is no blower motor. my question is if i install a blower motor, will i be able to use my heat in the car since that hole is covered? there is a heater core.thanks in advance.
Old 03-10-2005, 11:18 PM
rat tuned rat tuned is offline
Default Re: 70 chevelle fuel lines
as far as i know the low hp cars with quadrajet carbs the vapor return lines. the hp cars with holleys had a single 3/8" line with no vapor return. mike
Old 03-13-2005, 04:00 AM
k92 k92 is offline
My original '70 LS6 has the vapor return line.
