Old 04-04-2005, 05:32 AM
AMANOCC AMANOCC is offline
Default 1969 Camaro reverse lock out rods
Other than a stamped part #, how do i tell the difference between a small block and big block lower lock out rod?? Thanks
Old 04-04-2005, 04:01 PM
Default Re: 1969 Camaro reverse lock out rods
The length on both rods is about the same at 20". The big block and transmission are offset toward the passenger side requiring about a 3-5 degree bend in the rod on one end. Also, the rod should have 5776 stamped into the side, denoting the P/N.
Paul
