Old 09-09-2005, 05:51 AM
Born30YrsLate Born30YrsLate is offline
Default Stewart Warner 970-B Pedestal Tach
I am looking to buy/trade for a Stewart Warner 970-B (Custom Face - Green line) pedestal tach. I may have a MINT 977-J black face SW pedestal tach for trade or trade plus cash for the custom face tach. The 970-B tach needs to be in near mint or better shape.
Thanks...
Feel free to correct me if I don't have the part numbers correct for the tachs
I don't think it was coincidence that the Great Depression happened during Prohibition...
Old 11-06-2005, 07:49 AM
Default Re: Stewart Warner 970-B Pedestal Tach
I'm still looking for this tach...also have for trade mint dual dupree fuel pumps...
Old 11-06-2005, 11:31 PM
COPO COPO is offline
Fred, Sent you a PM
Old 11-06-2005, 11:54 PM
396L35's Avatar
396L35 396L35 is offline
"All I want for Christmas is a COPO or Yenko..." Isn't that a little too much to ask for Fred???
Mark
Old 11-07-2005, 05:56 AM
Some days Christmas is closer than others...but I've been a REALLY good boy this year and Santa doesn't always wear a red suit and have white beard...
Old 11-08-2005, 01:53 PM
enio45 enio45 is offline
Does the 970 B require a transmitter /sending unit for the tach? Also, is anyone aware how to get the front face (plastic lens off)??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-08-2005, 04:56 PM
camarojoe's Avatar
Yes, all 970 model tachometers require a sending unit to operate. If it is a pedestal tach, the entire outer chrome bezel is pressed on and has little bumps to hold it to the main case... You will see where the bumps are from the outside, as there are dimples visible on the outside chrome outer ring... sometimes the ring can be pulled off by hand, but usually you'll need to "knock" it off... Use a screwdriver with some tape wrapped around the tip to prevent scratching, and give it a light tap, the whole lense and outer ring should pop off, and the plastic lense can then be removed from the backside...just be careful....
-JB
Joe Barr
Old 11-09-2005, 03:09 PM
Joe, thanks for the advise...i see the dimples and will work the cover off. Reasin i asked is that the 2nd owner of my non coverted copo just sent to me the pedestal tach and the SW oil gauge. He indicated that when they went to pick up the car at Yenko new (he and the first owner were friends) the SW pedestal tach and the gauges were already installed in the car....obviously the motor was not swapped out yet. Anyhow he sent me the parts and some pics of it in the early yrs. When we restore it, we will put the Tach and Gauges back in. The lens has a few marks that need to be buffed out. Ill look around for the correct sending unit. Thanks again for the advise.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
