Old 09-27-2005, 01:14 AM
larane larane is offline
Default 69 Z28 Firewall Tag Info
Looking for some info...Some Z28's have the X33 code my car is from California built and it has the Q533 code. What does this mean??
Old 09-27-2005, 02:17 AM
JChlupsa JChlupsa is offline
Default Re: 69 Z28 Firewall Tag Info
You have a LOS built car so there will be NO "X" code on it. Norwood cars yes but after a certain date.
Heres some good reading from the folks over at the Camaro Research Group (CRG) Click on line item #11
http://www.camaros.org/numbers.shtml
Old 09-27-2005, 02:58 AM
Jonesy's Avatar
Jonesy Jonesy is offline
It's a Fisher Body scheduling code that the LOS plant used and really has no meaning that is useful.
Old 09-27-2005, 04:39 AM
Thank you HawaiianCamaro and Jonesy. This is good info. I have owned the car for 28 years and am currently restoring it back to the original configuration. Any information I can find will be helpful... Again.. Thank you both. The car originally came with a M22 transmission with no stripes. It is fathom green. I use to bracket race it. The best run was 12.40 @ 117mph on street tires with nitrous.. It has been fun but time to bring it back to the original state.. Thanks again.
Old 09-27-2005, 07:19 AM
Larane...Did you look on top of the gas tank for a build sheet ?
Old 09-27-2005, 06:31 PM
resto4u resto4u is offline
Does the m22 trans have your cars vin# ? Roger
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
