Old 10-01-2005, 04:04 AM
njsteve njsteve is offline
Default Needed: rubber seal for steering column joint
Does anyone out there an extra one of these rubber seals? It covers the universal joint inside the steering column coupling. This is for my 72 Trans Am, though it is a common part for all GM steering columns through the 70's. As you can see the original was fried in the previous owner's engine fire. New or used would be fine, I'm just trying to keep the dirt out. Thanks, NJSteve
