Old 01-07-2006, 04:49 PM
BillD BillD is offline
Default Clutch/Flywheel advice
I am getting ready to order a clutch and flywheel for my 1968 Camaro. Any recomendations on type or manufacturer? The car currently has a turbo 400 behind an L72 (427/425) with 4.11's. The turbo 400 is being swapped for a M-22. Car is driven maybe 200 miles a year but it does see quite a bit of extreme usage when it is out and could actually end up going down a track on occasion. I generally run M&H (10 inch wide) muscle car drag tires on it. Thanks for any suggestions
Old 01-07-2006, 05:15 PM
rubbinisracing rubbinisracing is offline
Default Re: Clutch/Flywheel advice
Try "Centerforce" brand. Alot of pressue and easy to push. They use a unique centrifugal setup to increase pressure without wearing you out and always bark the ties a little for that just right sound with no rpm run up. Summit has them.
Howard
Growing old is a certainty, growing up isn't
Old 01-07-2006, 06:22 PM
WILMASBOYL78's Avatar
Ditto on the Centerforce clutch. We have them in a number of our cars and they work great.
www.centerforce.com
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-07-2006, 08:07 PM
MosportGreen66's Avatar
Also look into the Hayes and Ram units.
I personally think with a BBC car, Centerforce units are weak.
Old 01-07-2006, 08:39 PM
GM-26's Avatar
GM-26 GM-26 is offline
I have had a 11" Hayes "Street & Strip" diaphram clutch in my Chevelle since 1988 and it still works great.
Nick...
Old 01-08-2006, 02:32 AM
Thanks for the input. I have used a centerforce with good results on an LT1 but didn't know if it would stand up to the big block.
Old 01-08-2006, 03:18 AM
Don't get fooled by pedal effort. I run one behind a Yenko clone thats a 427/550 dyno'd and never made it slip with radials. Never used slicks or with mini tubbed ford 9" though. That could make a difference.
Howard
Old 01-08-2006, 06:29 AM
don't do it... the product is weak. We had to change one out of the L-72 Corvette.
Old 01-10-2006, 03:41 AM
Anyone running a McLeod clutch? Or have any opinions on it or other brands? Sorry for all the questions but I really want to pick the correct clutch and do this job once.
Old 01-10-2006, 04:25 AM
Belair62 Belair62 is offline
Gowith a Hayes setup...Its always been good stuff...you really can't go wrong...
