I am selling my 72 RS Z28 (1 of 2575). It is the real deal as indicated by VIN and trim tag. The car runs and drives fine. But it does need a total restoration. With exception of one hole quarter sized hole the floors are pretty solid. The frame rails look to be in good shape up until the rear spring shackles where they are rusty. The rear body panel is pretty bad. From what I can see the cowl area is pretty Ziebarted and looks solid. Subframe also looks very good. I drove the car during last summer and had a blast with it. The car is Mulsanne Blue/Blue car DX3 no stripes. But now it is painted in a teal blue. Supposed to have blue interior but now has mostly black.
The original drivetrain is long gone but here is what it has. The 427 is from a 400hp tripower 69 Vette (512 block dated F 30 9). It has the oval port heads and a intake from a 65 Vette I believe. It also has the TH400 from the same 69 Vette. It is a 12 bolt with heavy duty goodies in it. Here is a list of what is has: MOTOR: 427 FROM A 1969 CORVETTE Upgraded 4 bolt main caps on the crank Line bored, balanced and decked 11:1 forged pistons Melling high volume high pressure oil pump Mallory 60,000 volt promaster coil with unilite distributor Manley Pro flow stainless steel valves 2.19/1.88 Competition Cams Street Magnum roller rockers Hooker Headers with Flow Masters TRANNY: Turbo 400 short tail from same 1969 vette Cheetah shift kit 11” B&M 2500 RPM stall converter B&M Star shifter REAREND: 12 Bolt Strange Racing pro-street axles Moroso Brute strength posi-unit 3:73 gears (also have 4:11) Centerline Rims Polished with rivets with cooper cobra GTS tires $6500.00 or reasonable offer Email me at [email protected]. (<- there's a "_" in between my first and last name) THANKS! |
