Old 04-24-2006, 02:25 AM
Z28fan Z28fan is offline
Default 69 Hugger Orange SS Camaro (454cid w/blower)
I've owned the car since 1994 and it's been a lot of fun over the years, but it's time to let go. Here's the specs on the car.
Exteior
Hugger orange paint with black hockey stripes.
4" Fiberglass Cowl Induction Hood (also comes with the stock SS hood)
GM Rally Wheels all around
Interior
Black Interior
New Houndstooth Seats (new padding)
New Dash Pad
New Deluxe Door Panels
New Black Carpet
Hurst 4spd Shifter (no console)
High Performance Gauges
(too much to list here)
Drivetrain
454cid (std bore) with Weiand 6:71 polished blower and
dual 750cfm Holley carbs (professionaly built by Jim Taylor Racing Engines in 1999) less then 300 miles on engine
Rectangular Port Cast Iron Heads(GM)
Crower Valve Springs
Manley Valves
TFX Custom Solid Lifter Cam
Forged GM Crankshaft
Forged Flat Top Pistons
High Perf. GM Rods with ARP Rod Bolts
High Volume Oil Pump
(All the best parts used to build this motor.)
Be-Cool Aluminum Radiator with elec fan.
Holley High Volume Electri Fuel Pump
Complete MSD Ignition Setup with special smaller diameter Distributor (for blower clearence), Blaster 2 Coil, Rev Limiter and adjustable Ignition Timing Retard Control (from inside car)
Muncie M-21 Close Ratio Transmission (rebuilt in 95)
Blow Proof Bell Housing
Centerforce Clutch Assembly (with counterweights)
Frame Connectors
GM 12 Bolt Posi Rear with 3:73 Gears
Stainless Steel Brake Lines
& much, much more!
Do to health problems the car has been parked for the last 4 years but car is now running and ready to go. I hate to sell it but hopefully someone will enjoy it & have fun with it as I have over the last 16 years.
[email protected] or call 610-253-0929
Color Photos available.
$32,000.00 or best offer
I'm located in northeastern PA. and would be glad to show the car to you if you'd like to come see it.
Thanks, Jeff S.
Jeff_S.
Olympic Gold 69 Z/28 Camaro
Hugger Orange 69 SS Camaro
