1969 396-375HP motor
Originally out of a 1969 chevelle and has the front pad information of T0416JD representing a 396-375HP 4speed motor with the vin number from the chevelle of 19B379312. The motor was all cleaned up and greased down and will remain standard bore. The pistons and dimple rods are their along with a standard 6223 crankshaft. The block casting number is 3955272 and it looks to be dated A-9-9 (hard to read). The motor comes with all new bearings, high volume oil pump, new camshaft with lifters (factory replacement), complete gasket set, 840 heads all redone dated C-27-9, 163 aluminum intake dated 4-4-69, alternator 837 D-3-9 and distributor 499 dated D-2-9 (both restamped and all rebuilt, hard to tell the difference), alternator brackets, harmonic balancer, oil pan, timing cover with new double roller timing chain. $5500 firm. Apart for inspection. 330-638-0511 Dennis
Dennis Vugrinovich
