Old 07-17-2006, 09:15 AM
TXSS TXSS is offline
Default ZL-1 Powered 1969 Camaro
This is the second ZL-1 powered Camaro I’ve built this year. Like the first, I built this car to drive, with the options that I would have ordered and as close to an original ZL-1 as would matter from a visual, driving or performance stand point.
#1 Frame off restoration on what was originally a very rust free Norwood X11 Camaro. All original body panels and floors. Body was media blasted and painted in show quality PPG base coat / clear coat. Undercarriage is like new. Virtually everything on this car is new or restored to like new condition.
This is a GM 3946053 ZL-1 block. With the exception of being built to 10.5:1 comp. ratio the engine was built to ZL-1 specs using the correct .620 lift mechanical cam.
Engine and transmission are fully warranted for the next 6 months
I have tons of pictures, so just ask.
Options:
COPO 9560
ZL-1: All Aluminum GM 427cid 535 hp
M22: HD Muncie 4 Speed “Rock Crusher”
G84: 4:10 Positraction Rear Axle
J52: Power Front Disc Brakes
K66: NOS Mag Pulse Ignition System
N33: Tilt Steering Column
C48: Heater Delete
.....: Radio Delete
COPO 9737 Sports Car Conversion
15” Rally Wheels
13/16” Front Stabilizer Bar
140 MPH Speedometer
Interior: 711 Standard Black Vinyl
Exterior: 72 Hugger Orange
Block 3946053
Intake 3933198
GM Aluminum Heads 3946074
Holley Carburetor 4296
7115 GM Steel Crank
TRW Pistons
Mag Pulse Ignition System: Dist 263 Amp. 343 (Not Installed)
Delco Starter 1108351
Correct ZL1 .620 lift mechanical cam
Correct Bent Neck Radiator
Correct 403 Bell housing and ZL1 clutch configuration
1969 Date Coded M22 Muncie 4 speed
Original 1969 Hurst Shifter
Inquires regarding this car can be made to Rick at 713-705-2491
[email protected]
89,000.00
Thanks
Rick
Rick
Old 07-18-2006, 02:53 AM
71-LS6 71-LS6 is offline
Default Re: ZL-1 Powered 1969 Camaro
Wow Rick, you are a one man ZL1 plant. That thing looks as nice as the last one you did.
Steve H.
industrial art collector
Old 07-18-2006, 05:09 AM
southernfriedcj's Avatar
Awesome looking car. I wish I had an open bay and 89k!!
Old 07-18-2006, 07:23 AM
BBIGG BLOCK 396 BBIGG BLOCK 396 is offline
Damn I love that color,the car is absolutely BEAUTIFUL!
Bobby Dodson
Old 07-18-2006, 08:51 PM
4406pk 4406pk is offline
The car is "Awesome" ... Wish I had a slot for it in my gargage. Great Work .. Congat's on a job well done..
70RR4406pk
Old 07-18-2006, 08:54 PM
427TJ's Avatar
427TJ 427TJ is offline
Somebody loan me 90 grand---FAST!!! x 1,000
Nice work Rick. Can I drop-off my '67 at your shop someday???
Old 07-19-2006, 04:12 AM
Thanks for the positive comments. All the comments from members of this site mean a great deal to me.
I've been ask to post a picture of the radio and heater control area as well as a few under carriage pictures.
Bill - You can drop the 67 off at my place anytime.
Thanks again
Rick
Rick
Old 07-19-2006, 04:13 AM
I can't stop looking at this car. I want it! I hope it sells soon, or I might have to dump some of my junk and step up.
Old 07-19-2006, 07:15 AM
396L35's Avatar
396L35 396L35 is offline
Rick you have one nice car but I did see you are missing the dash emblem and the heater delete plate lines should be running up and down... Other then that, she is a sweet ride, can I have it???? Great job with the resto, the undercarrage is clean enough to eat off...
Mark
Old 07-20-2006, 01:26 AM
SOLD---SOLD---SOLD---SOLD
The Supercar Registry is the #1 Muscle Car web site in cyberspace....period.
Thanks
Rick
Rick
