Old 09-23-2006, 05:58 AM
BBIGG BLOCK 396 BBIGG BLOCK 396 is offline
Default Found this on Craigslist
Reply to: [email protected]
Date: 2006-09-22, 6:47PM CDT
Come and look this weekend, she's shined and polished, waiting for a new adventure! She's been babied - never seen a drop of rain, was my husband's reason to hang out in the garage for a few years.
1970 Chevelle SS 454 LS-5. Astro blue with white top (no vinyl—rare and correct), black interior, bucket seats. Numbers matching, extremely clean, original, slick paint and interior. PS, PB, Auto, Power Windows, AM-FM 8 track. Only restoration so far was parts replacement or enhancement. Original build sheet. Clean, and straight! Spare 454 (425HP) in car now so you can play with it while the orig #’s match waits in storage to run again. Original NOM engine to be sold with the car.
Removed original numbers matching 454. Was smoking (looks like valve seals on heads—compression 135 when removed). Similar 454 built as a spare by local expert with extras. Of course all new high quality parts—crank, bearings, rings, lifters, valves etc. 10.5 to 1 hypereutectic pistons (ARP rod bolts), crane hyd cam, roller rockers, completely balanced. Edelbrock Performer intake, Holley 850 DP carb, Hooker 2” coated headers, All new bolts, chrome where possible. Engine broke-in on Dyno---pulls showed max HP est at 425. All original parts removed that came with original numbers matching 454 included (carb, exh manifold, starter, etc.)
NEW PARTS OR REPLACED PARTS IN ENGINE AND UNDER HOOD
Chrome radiator cover, chrome hi-torque mini-starter
High flow water pump, chrome water neck, chrome timing cover
Original design chrome valve covers (thicker VC gasket allowed clearance for roller rockers)
100 Amp internal alternator (original retained) with kit to bypass voltage regulator, horn switch
New Delco Battery and Cables (went with current style battery rather than orig).
Master Cylinder and pads on front
AC Condenser and hoses
4 row radiator and hoses and heater hoses, radiator bushings, water temp sending unit
Steering sector and rag joint
Power steering hoses, front wheel bearings and seals
Cowl induction vacuum module, valve, hoses.
SS hood springs and hood insulation and exterior hood hold down pins and clips
Blasted hinges and clear coated
New speedometer gears in trans
New fan and fan-clutch
Chrome transmission pan, B&M 2800 SS torque converter, B&M shift modulator
Chevy/GM factory solid motor mounts
Chrome rear end cover
INTERIOR ETC.
Light switch instrument light bulbs. Removed radio for tuning and 8 track repair—shop could not fix
Replaced clock with orig with new one—can’t get to work now, tested OK when received.
Transmission shifter cable, Radio and shift lenses
Added mechanical oil and water temp gauges
Have new chrome seat trim—not yet installed
New original Chevrolet ignition, trunk and door locks not yet installed
New power window switches not yet installed
Reproduction headrests
Spare cover (same as current mat and the original pattern in trunk now) but did not match
MISCELLANEOUS:
Original Build sheet
Official restoration info from GM
Lots and lots of books, manuals, and literature
Parts listing (copied)
GM Parts CD
GM Repair CD
Lots and lots of research….
Email for additional information, pictures or questions: [email protected]
**SERIOUS INQUIRIES ONLY**
This item has been posted by-owner.
this is in or around Houston, TX
no -- it's NOT ok to contact this poster with services or other commercial interests
210975618
Old 09-23-2006, 06:07 AM
Rixls6 Rixls6 is offline
Default Re: Found this on Craigslist
I think this same car is listed on Ebay. Astro Blue with white painted top.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 09-23-2006, 09:14 PM
TXSS TXSS is offline
I looked at the Chevelle a few months back when the seller was asking 52 or 53 for it.
Rick
Rick
