Old 10-31-2006, 02:40 PM
BillD BillD is offline
Default 2 piece front disc brake rotors
I am trying to find make a good set of 2 piece front disc brake rotors for a 68 Camaro. I have one with enough meat to turn and use, One is a little thin. 2 questions if anyone can help. What is the minimum thickness I can use? And what other model cars & years (Nova? Corvette?) would use the exact same rotor?
Old 10-31-2006, 03:11 PM
Hylton Hylton is offline
Default Re: 2 piece front disc brake rotors
If I am not mistaken, someone is reproducing them now. Just buy new.
It is impossible to certify a COPO or Z/28 as authentic without verifying that it is not a rebody...
Old 10-31-2006, 04:30 PM
I think the repro's are one piece?
Old 10-31-2006, 05:39 PM
As I recall, 0.890 is the minimum rotor thickness.
Can anyone verify
Old 10-31-2006, 06:23 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I thought it was 0.900 minimum thickness.
Old 10-31-2006, 09:06 PM
Tonyx33 Tonyx33 is offline
.865 That was stamped on mine.
Old 10-31-2006, 10:52 PM
.965 minimum the machine shop book said. I have the originals and they are slightly less with NO problems. I don't heat them up like you would on day to day hard driving. Unless they are real thin I can't see a problem. Wern't the same rotors used on camaro, chevelle and nova thru 1970?
Old 11-01-2006, 12:34 AM
NCGuy68 NCGuy68 is offline
For a show car or lite duty driver, .850 is fine. Over the years, I've cut a bunch of them to this with no problems.
If your gonna Stomp on them hard and often, go with the Min. thickness marked on the disc.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
