Old 12-29-2006, 04:47 AM
Default 1969 Camaro 12-bolt
------The date codes are correct and I cant imagine, looking at the car, that anyone went searching for a date coded rear, but are these #s correct for a 69 Z???
--------BU 0506G1
-------------E
---------Thanks,,,Bill S
Old 12-29-2006, 04:49 AM
JRSully JRSully is offline
Default Re: 1969 Camaro 12-bolt
yes, 3;73 ratio I believe (BU code), stock for a 69 Z
71 Porsche 911 Targa
Old 12-29-2006, 04:56 AM
Yep..decodes as a 3:73 posi,May 6th,Detroit Gear & Axle,1st shift,Eaton carrier.
That code was shared on the 66-69 Nova & 68-69 Camaro too.
Check the 4 O'clock pumpkin webbing for a casting date.
Old 12-29-2006, 08:02 AM
-----Thanks, guys,,,,I appreciate it. Date code is correct as well........Bill S
