Old 12-29-2006, 12:22 PM
TDW TDW is offline
Default 350 LT1 compression...Lower it?
I took the engine from my 70 Z28 to the machine shop. It needs .030 over pistons. I bought a set a while back. TRW, GM replacement pistons. The engine builder wants to cut the pistons compression ratio down to 9.3 to 9.5. I don't drive the car too much,so I am thinking about leaving them at 11.1 and running a Crane Blueprint Series factory spec LT1 cam. Any thoughts are welcome. What have you guys with this engine done at rebuild time? Engine builder says it won't run on 93 octane, but my L78 and my 302 both run good on 93 pump gas.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 12-29-2006, 02:52 PM
Chevy454 Chevy454 is offline
Default Re: 350 LT1 compression...Lower it?
Follow *your* gut, Tony...I'll betcha a barley pop those TRW pistons would spec out too short [as is] and you'd be low on compression, especially if you haven't gone hog wild with decking the block...tell him to leave the pistons as is, cc everything, and I bet you'll see 10 to 10.5:1 *max*...also, that Crane cam is the way to go...
Old 12-29-2006, 03:56 PM
I'll bet on it being 10:1 tops. If your really concerned, cc your head to see how close it really is to spec.
Peter
Old 12-29-2006, 04:31 PM
I agree with both these gentlemen. My 302 came out to 10.4:1 with TRW's and the head work. I used the Crane blueprint cam also. Never have problems with gas or heat. Sam
Old 12-29-2006, 04:54 PM
TDW TDW is offline
Thanks guys. That is excatley what I wanted to hear!
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 12-29-2006, 05:06 PM
YENKO DEUCE REGISTRY's Avatar
I used the TRW's with a .030 overbore, I know it's not 11.0:1 - and it will run ok on 93 octane, it likes a little more, but will dawdle around on 93. Don't go with 9.x's
Marlin
Old 12-29-2006, 05:53 PM
------Every point of compression is worth somewhere around 50 to 75 horsepower so let the emasculation begin!!! Dont let him talk you into the drop. The little amount of time we spend in these cars these days, its worth finding a bit of racing gas if you do have a slight ping problem. The sound is different as well. Its like putting a hydraulic cam in a solid lift motor, just doesnt sound right. Half of the heart of these cars we are interested in is the sound.....Bill S
Old 12-29-2006, 05:58 PM
BUIZILLA BUIZILLA is offline
What head gaskets are you using ?? there is a HUGE difference right there.... the stockers were .020 compressed, you can use the .039 FelPro gasket and be just fine with the stock pistons, 93 gas, and 34* total timing..set the initial at 14* and put 10 basic in the distributor curve and that'll give ya 34* total. It'll run perfect.... my LT-1 is 14.95-1 and I kinda like that myself...
JH
aka - Mighty Mouse
Old 12-29-2006, 06:03 PM
------WOW!!!!!! Jim,,,,That thing has got to crackle. Anybody indexing plugs down there???......Bill S
Old 12-29-2006, 06:13 PM
Our L78 runs fine on 91-93 gas as does our '70 455 Pontiac. I think the key is a curve as mentioned above and possibly run slightly rich. 40 degrees was fine for 102 grade gas. These cams bleed off quite a bit of cylincer pressure. More cam would help the situation more.
