Old 03-03-2007, 03:48 AM
mudjnky mudjnky is offline
Default Muncie Trans ID
I am converting my Wife's Camaro to an auto trans so she can drive it. Before anyone says "Don't do it, teach her to drive a stick", it ain't happening. Been there, tried that, the car is getting an automatic. I wanted to see if the 4 spd was anything special before selling it. There is a tag on it that reads 9784425, two numbers on the side of the case are P7T07 and 3885010. The numbers were given to me by the guy working on it so hopefully they will match up to something. Any help in identifying it is greatly appreciated.
Old 03-03-2007, 03:54 AM
Rixls6 Rixls6 is offline
Default Re: Muncie Trans ID
I'm not an expert, but P7T07 breaks down as Muncie, 67, December, 7th.
The 3885010 case was used in 66 and 67 model year.
If there's a VIN stamped somewhere, it may help decipher further.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 03-03-2007, 04:58 AM
Thanks Rick, not sure if there are any other numbers or not. Basically trying to figure out if it is a run of the mill Muncie or if it had some special application.
Old 03-03-2007, 05:05 AM
See how many rings are on the input shaft.
2 Rings is M20
1 Ring is M21
0 Rings it may be a very rare 67 M22. Also would have a drain plug on the side bottom, where the others wouldn't.
If there are no rings on the input, then
open the side cover after you drain the trans.
See if the gears are cut at about a 45 degree angle or a 20 degree angle.
20 (or thereabouts)degree is M22. CHA CHING.
Rick
Old 03-03-2007, 06:30 PM
Have to check that when we get it out
