Old 05-04-2007, 12:53 AM
COPO CARTEL COPO CARTEL is offline
Default jack
Guys I am looking to buy a 69 Camaro dated original jack. The month I need is H 9 for August or I 9 for September. Thanks please PM me Doug The date is located on the small rivet about half the size of a dime on the jacking portion of the assembly.
Drive it ...Like you STOLE it !!
Old 05-04-2007, 05:03 AM
nova7579's Avatar
nova7579 nova7579 is offline
Default Re: jack
The I was skipped when date coding. They used A-H and J-M.
Brian
Old 05-04-2007, 04:47 PM
427L88 427L88 is offline
Default Re: jack
Brian
I told you Doug...
Old 05-04-2007, 09:46 PM
Default Re: jack
Yes Ted you are right. sooo now I am looking for a H or J code. thanks, ha ha
Old 05-05-2007, 04:25 PM
69 Code51 Z 69 Code51 Z is offline
Default Re: jack
What are jacks bringing these days? I've seen some on E-Bay that go cheap and others $$$$. Is it because of the date?
R, Carl
Old 05-08-2007, 05:22 AM
lbnaz lbnaz is offline
Yenko Premier Member
Default Re: jack
Hello, I just took a jack out of a 1A CA. car and there is nothing stamped on the rivet. It has 1969 on the horn and a 8 at the top of the mast under the stop area. Its still the grey in color with a little rust on areas. Has anyone seen one like this before? It will be for sale also. Larry.
Old 05-08-2007, 03:57 PM
Woj's Avatar
Woj Woj is offline
Default Re: jack
Not all jacks were stamped with dates. Some had no stampings at all. You might consider something with no date.
Phil Woj.
