Old 09-13-2007, 08:11 PM
SUPERSPORT SUPERSPORT is offline
Default 1969 Chevelle SS 396 L78 car, Frame OFF 4 speed!
http://cgi.ebay.com/ebaymotors/Chevrolet...1QQcmdZViewItem
Asking $42,000
Old 09-14-2007, 04:47 AM
GTO_DON GTO_DON is offline
Default Re: 1969 Chevelle SS 396 L78 car, Frame OFF 4 speed!
Im not trying to be mean but in your ad you say its wearing its original ss badges but in the pics you can clearly see they are crooked and in the wrong spots. How do you know its a real 375 horse car? I would need to see some solid proof before bidding.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 09-14-2007, 07:37 PM
The badges are in the factory holes on the cars original body panels. So its IMPOSSIBLE to put them in the "Wrong Spots!"
Old 09-14-2007, 08:40 PM
Rainer Rainer is offline
I'm with Don - there is severe misalignment of the fender emblems. This is just not seen in factory-installed pieces since the holes were made from a template. If the restorers simply reinstalled the emblems in the existing holes in these fenders, then these fenders were replaced on the car at some point.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 09-14-2007, 08:42 PM
427TJ's Avatar
427TJ 427TJ is offline
You never know, maybe the assembly line emblem hole-driller guy had a few too many at lunch that day? Keep in mind that while we restore them to Pebble Beach levels of detail today, Chevrolets have always been built as quickly and as cheaply as possible and attention to detail on the assembly line was/is not always Job One.
Old 09-14-2007, 08:53 PM
The fender emblems on our '69 are above the top of the wheel well lip. Baltimore car. The fender either went into a fixture that drilled the holes or a jig clamped to the fender and the holes were drilled manually. May have been pierced. Any way you look at it, you aren't going to get the holes an inch or two out of position no matter what the operator had for lunch: Buried in the GM manuals are dimensions for where these holes are supposed to be. When I bought our COPO Chevelle, I had the dealer install the SS emblems with the Corvette 427 number underneath. They put everything way low. Dumb on their part and dumber on my part for getting it done. Kids will be kids. These cars are 38 years old and unless you have owned it from new, there is no real way of knowing what they have gone through. In salt country, the front fenders had rust holes behind the front wheel in three years. Been there. An awful lot of these cars would have had their fenders repaired or replaced long ago. Might have been what happened with this car. The purists will want to change 4-5 things under the hood. The expensive part being the exhaust manifolds and smog system.
Old 09-15-2007, 05:26 AM
kwhizz kwhizz is offline
I would think that the holes would be punched in a die during the manufacturing process.......
Ken
Old 09-15-2007, 06:01 AM
Usually parts would be pierced. One example of drilling, was when we built the Dually trucks a few years ago. The side of the box was cut out with a plasma cutter then the box went into a station where the sides were drilled for the attaching clips. If I get the time, I can dig out a pair of original used SS396 fenders that I have and give the holes a close look. Piercing and drilling don't look the same.
Old 09-15-2007, 07:18 AM
All good info. Thanks
Old 09-15-2007, 08:49 AM
There you have it!!!
Heres Tom with the weather!!!!!!!!!!!
