Old 11-01-2007, 01:09 AM
Mike Petrillo Mike Petrillo is offline
Default Engine Block Repair
I am looking for a machine shop that can repair a vintage L79 block that has some outside water jacket cracks.Since this block is the original & not decked I am trying to find a shop in the northern california area as I do want this valuable part of my car to be to far from me.Any info would be great.
Thanks Mike
Old 11-01-2007, 01:56 AM
VintageMusclecar's Avatar
Default Re: Engine Block Repair
Mike;
Check this out.
Eric
Old 11-01-2007, 05:35 AM
Belair62 Belair62 is offline
Damn...in California no less !!
Old 11-02-2007, 12:21 AM
I spoke with the folks at Full Torque today &amp; will bring them my block for repair.I should have it back in 30 days or so &amp; will share the information of the repair with everyone.Thanks for the tip,the process sounds way better than welding.
Old 11-02-2007, 01:21 AM
Neat process. You know what they say... " a stitch in time saves nine" or in your case saves an L7 9 !
Old 11-02-2007, 01:46 AM
Casey Marks Casey Marks is offline
I'm here to tell you that this process DOES work ! I have a customer motor that I recently completed that had a similar problem. 413 Cross Ram Mopar. Numbers matching for a 1 of 75 '61 300G Convertible. Crack on the outside of the block. We "stiched" it and not only is there no more problem, but you'd be hard pressed to see the work. My first coat of paint on the engine, and you couldn't see it anymore. GOOD LUCK !!!!
