Old 12-27-2007, 08:33 PM
VintageMusclecar's Avatar
Default 12 bolt brake hose t-fitting--HELP needed a.s.a.p.
In a futile attempt to get the rear brake system together on my Chevelle's 12 bolt, I have ran head-first into a rather surreal roadblock. Frustration levels are rather high at the moment, so forgive me if I ramble...
I have 2 different "t-fittings" for the rear brake flex hose; an original 10-bolt style that has the correct inlet and outlet thread sizes, but lacks the small drilled boss to bolt the fitting to the correct 12 bolt brake hose bracket, and the other which looks like a correct 12 bolt style fitting and has the correct drilled mounting boss and outlet thread sizes, but has an incorrect 3/8-24 inlet thread size instead of the required 7/16-24 where the flex hose attaches.
I've already tried OPG, Chevrolet Restoration World, and Ground up--none of them show the correct 12 bolt t-fitting, all they show is the 10-bolt fitting. I've already scoured the Dorman drawers as well as the Dorman catalog at my local NAPA. No correct t-fitting, nor could I even find a suitable adapter to go from the 3/8-24 (male) to the 7/16-24 (female) with the correct conical sealing ends so I could use the fitting I already have that has the required drilled mounting boss.
(Assuming such an animal even exists), I need to find a 12-bolt t-fitting that has the drilled mounting boss AND the correct 7/16-24 inlet threads for the flex hose.
HELP?!?
Eric
Old 12-27-2007, 09:58 PM
COPO CARTEL COPO CARTEL is offline
Default Re: 12 bolt brake hose t-fitting--HELP needed a.s.a.p.
Eric you have a PM
Drive it ...Like you STOLE it !!
Old 12-27-2007, 10:13 PM
OK, problem is solved.
For future reference in case anyone else runs into this issue, it turns out there are differences between `67-`68 12 bolt brake hose brackets and the `69-`72 style. The `69 style rear flex hose has the t-fitting built onto it, the `67-`68 takes a separate line and t-fitting. I have the `69 style bracket which doesn't work with the `67-`68 line and t-fitting. A new `69 style hose will be here in the morning which should solve the problem.
Learn something new every day.
Eric
p.s. Happy birthday Doug, and thanks for the PM
