Old 05-30-2008, 04:15 AM
Tommy_Mathison Tommy_Mathison is offline
Default Delco batteries; Y77 vs Y89
What are the main differences between the two? Are they interchangeable?
Tommy Mathison
Old 05-30-2008, 06:19 AM
Default Re: Delco batteries; Y77 vs Y89
The Y77 had 3/8" & 5/16" side terminals along w/a 45 amp hour rating and 2300 cold cranking watts and weighed 34lbs.
The Y89 had both 3/8" side terminals along w/a 61 ahr,and 2600 ccw. and weighed 44lbs.
The Y89 is a little larger,but will fit in the same tray.
They both had std. terminal positions,but you're gonna have to adapt a battery cable post to accomadate one or the other.
Old 05-30-2008, 07:44 PM
So what was the Delco replacement for the Y77? The must have kept producing it after the 69 model year?
Tommy Mathison
Old 06-01-2008, 07:15 PM
I think the the Y77 assembly line installed vehicles used the Y87 as their later service replacement.Then the 5/16" negative terminal cable had to be updated by the installing mechanic,which was the same scenario for the R79 being replaced with the R89 series.
The VERY short lived safety feature of a 5/16" negative terminal design proved to be more of a nuisance then previously thought.
Old 06-02-2008, 12:00 PM
Kurt S Kurt S is offline
http://www.camaros.org/underhood.shtml#Batteries has some battery info.
Kurt S - CRG
Old 07-01-2008, 10:31 PM
LITTLE TOMMIE LITTLE TOMMIE is offline
does anyone repo the y55 battery or does every one use the r59 repo for there 69 z28 resto
Old 07-02-2008, 06:08 PM
I don't think anyone has reproduced the Y55.
Too few applications is most likely why.
I watched an NOS original Y55 in the box sell for 1K this past February.
Old 07-03-2008, 02:10 AM
John Brown's Avatar
I know it's a really loong shot, but FIAT put Y55 batterys in some of the cars they imported to the east coast in the 70's. Of course finding a FIAT dealer may be harder than finding a Y55.
John Brown
