Asking $145,000 - 1967 Corvette Coupe, 427/435HP Tri-power, Goodwood Green , #’s matching, documented w/ Protect-0-Plate, tank sticker, sales invoice, window sticker, Mint NCRS show quality Frame-off restoration, ultra rare 1 of only 3 known with these sought after options. This is a genuine 4:56 rear car. 427/435hp tri-power V-8, has all its pedigree documentation. This 67 Corvette Stingray Coupe has the extremely desirable, very rare “JE” engine code (which denotes special High-performance, big block V-8, 427/435hp Tri-power) yes it is fully documented with all the factory paperwork: included is the factory protect-o-plate, the window sticker, the tank sticker, the sales invoice, original owners manual,the options manual, and much more included. It has had a recently completed total high-dollar no-expense spared, body-off frame to NCRS/Bloomington standards of excellence restoration completed.
This 1967 Corvette Stingray tri-power Coupe is fully documented and has its factory Protect-o-plate included in the sale. It was treated to a very high-quality full no-expense spared body-off the frame total nut and bolt restoration. It is an original 983 paint code correct Goodwood Green example that has been refinished in Dupont Lacquer to factory correct color codes, perfect gaps, and the flawless mirror finish is simply spectacular. All the chrome, stainless trim, emblems etc. have been show quality rechromed, or replaced with factory correct new show quality parts thru-out. Even the outside mirror is restored date code correct. The bumpers are the originals correctly rechromed. All the glass is tinted, original date coded there are no chips or scratches. The side exhaust covers are spectacular. The headlights have rebuilt motors and work effortlessly with correct T-3 lamps. The result here is spectacular no doubt a show winner or a fully prepared ready for Bloomington gold or NCRS Topflight certification. No details were left omitted in the restoring of this Corvette and it was used a total of 335 break-in miles so the condition of the performance is well established here with no mechanical unknowns as would be the case on a zero miles restoration. The interior has been completely restored and has been restored to Top Flight perfection and in immaculate condition. It has all the great options you could imagine from the rare power windows, telescoping steering wheel, all tinted glass, factory close ratio 4 speed, power vacuum disc brakes, headrests, shoulder harness, am-fm, TI ignition, one of the rarest options the special heavy duty brakes and so much more. The undercarriage is superbly detailed to NCRS specifications by the book with all the proper factory markings and one of the nicest 67 coupe frames you will ever see. Under the hood is spectacular and is highly correct NCRS quality detailed just look at the pix! That basically says it all if you want to own one of the best in existence here it is and there is premium price to pay for a high-quality blue chip investment 1967 Corvette 427/435HP Stingray Coupe. Serious on-site inspections by appointment only. The Options 1967 Corvette Stingray Coupe: - 2983 AA Goodwood Green - 2J50 MA Vacuum Power Brakes - 2G81UA Posi-Traction Axle 456R - 2J56 AA SPL HD Brakes - 2A31 AA Power Windows - 2M21 AA 4 Speed CL Ratio Transmission - 2N36 AA Telescoping Steering wheel - 2A01 BA All Tinted glass - 2A82 AA Headrest seats - 2A85 AA Shoulder Harnesses - 2U69 AC PB AM-FM Radio - 2430 FA Geen Interior - 2K66 DA Transistor Ign EG - 2N14 AB Side Dual Exhaust - 2K71 AA 435HP V-8 Turbo-Jet NUMBERS - Engine T1102JE 7103954 - Casting 3904351 - date J66 - Heads 390439 - Intake Manifold 3894374 - Exhaust Manifold L3880827, R3880828 - Carbs R. 3659 F. 3659 C. 3660 - Water Pump 385628 date G116 - Alternator 1100696 - date 6H11 - Radiator original Harrison K66 - Distributor 1111258 - Transmission P7P26 S103954 - Rear Axle FC10 3 66 casting date H22 6 - Front Shocks 3171488 - Rear Shocks 3171489 - Calipers dual pin design 5465954 outer, 5465952 inner - Proportion Valve 3878944 - Front Support Bracket 3882784RG 3882783 LH - Ignition Coil 1115263 - Shoulder harness original tags C20 date 40E66 (date Oct. 5, 1966) - Voltage Regulator 6H - Glass, left door vent, JA, left door, UA, right door vent, JA, right door TA, windshield UA, back window, UA All instruments including the clock work perfectly. Thanks for your interest... Dave (617)513-7407 / Email: [email protected] Car is located in Northern NJ - 40 miles W of NYC ![]() ![]() ![]() |
So what is the premium price for the car??
'70 L78 NOVA SS '77 Bronco |
It says he's asking $145k...it's on the first line
Bruce Choose Life-Donate! |
The only line I did not read...
The only line I did not read... ![]() ![]() [/ QUOTE ] LOL ![]()
