Old 12-28-2015, 02:13 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Re: undercarriage semi gloss black
I ended up using SEM Trim black on my floor pan and sub-frame. I used it over PPG epoxy primer in gray. I couldn't be happier with the results. Here's how it came out.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 12-28-2015, 09:17 PM
The Dude The Dude is offline
I still use Eastwood Chassis black. Not flashy but it works. And is close to the real color my frame was when new.
Old 12-28-2015, 10:30 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Interesting the a-arms were bare.. Very cool photo. Do you know the year it was taken & which plant?
Old 12-28-2015, 11:11 PM
1964, Fremont. That pic was before the blackout station.
After
Old 12-29-2015, 12:04 AM
cook_dw's Avatar
Very cool; thanks for sharing.
Old 01-02-2016, 12:04 AM
1968 nova ss 1968 nova ss is offline
Thanks for all the help and advice.. I ended going with a PPG DCC 9300 black,which is an acrylic urethane. with a 4985 flattening agent,dcx 61 hardener and a DT reducer... I like the semi gloss look...was slightly more than a semi gloss, but I would add a few ounces of flattener on the final coat to tone it down a little.always remember what each product role is on the formula...it you add more hardener it will get more shiner..i also used a DT 885 reducer that is used for some hot temperature . it dryer slower and will give you more time to spray the underneath of car. with it drying evenly..will post some pix hopefully tomorrow. Chris
