Old 12-02-2004, 04:53 AM
COPO COPO is offline
Default 69 Camaro Tachometer
What is the correct tach for a late March Build L-78 '69 Camaro? 6K Redline and 7K max, or 6K redline and 8K max?
Old 12-02-2004, 06:38 AM
Unreal Unreal is offline
Default Re: 69 Camaro Tachometer
All 69 L78 and l72 used 6/7 tach for the entire model year. Z/28 switched from 6/7 to 6/8 in early calendar year 69.
Anyone know why Z/28 changed, and solid lifter b/b did not?
Old 12-03-2004, 12:07 AM
Hylton Hylton is offline
Wind a stock L78 to 8 grand and you'll find out!
It is impossible to certify a COPO or Z/28 as authentic without verifying that it is not a rebody...
Old 12-05-2004, 03:43 AM
William William is offline
I hear the pistons try to switch sides about 6500...
Old 12-07-2004, 05:24 AM
The tach doesn't control RPM; it just reports it. Redline remained unchanged, so why change the tach? Are you suggesting that they changed the tach on the Z because it was OK to overrev it to 8 grand, but they left it at 7 grand for the L78/L72, because it was not OK to overrev it?
