Old 07-24-2008, 05:41 PM
Atuckman Atuckman is offline
Default Removing tank sticker (68/72 vette)
can anyone offer best practice to remove the tank sticker and how to preserve given chemical debris? appreciate the help
Adam
Old 07-25-2008, 05:19 AM
1railman 1railman is offline
Default Re: Removing tank sticker (68/72 vette)
Clean with soft brush and remove by cutting glue with razor knife. Go slow and easy don't hurry. Use magnifing glasses if necessary.
Old 07-25-2008, 05:30 AM
Leave it on the tank. Take a good pic of it. Cover it with plastic.
Old 07-25-2008, 09:56 AM
FASTONE FASTONE is offline
I wouldn't advise putting plastic over the tank sticker. A friend and I pulled the tank of his 68 435 car to find a fairly legible tank sticker. He covered a large area of the tank with plastic and put the tank in his garage on a shelf. A couple years later he uncovered it to find the sticker deteriorated beyond reading. Talk to a document specialist or library employee first. Hope this helps
Old 07-25-2008, 10:20 AM
rubbinisracing rubbinisracing is offline
Because their is no vin# on the tank sticker, photo and/or video evidence of the tank removal would be a big plus if you aren't past that point.
Howard
Growing old is a certainty, growing up isn't
Old 07-25-2008, 10:26 PM
Paper Chemistry was not very good nor was it aimed at creating archival records in the late 60's... it was acid based, which is why the paper yellows and gets brittle with age.
It must be neutralized in order to keep it from deteriorating any further... KEEP it out of the light... Light also causes it to decompose quicker.
Old 07-25-2008, 10:32 PM
thank you all for the advice and suggestions.
Old 08-09-2008, 04:22 AM
x  Baldwin  Motion's Avatar
sooooooooo.........how's that tank sticker look?
Z27 D019?
Old 08-09-2008, 03:03 PM
HiHorse HiHorse is offline
Adam
I took a tank sticker off a '67 435HP car in the 80's and ruined it, better to leave it alone and take photo documentation.
