Old 01-26-2009, 04:42 PM
Ngtflyr Ngtflyr is offline
Default 69 Camaro Parts
Horns #289L and #290H for Late Mar 69 build date
Rosewood Vinyl for dash (glovebox, ashtray etc)
Tips on restoring my original rosewood steering wheel
Linkage only for Hurst 4spd/camaro/M21
(I have the shift handle and linkage body)
Info on the proper way to block off smog tubes
and finally
Gold Chicken lips --- NOS right rear wheelwell trim
Dave
Old 01-27-2009, 04:11 AM
Unreal Unreal is offline
Default Re: 69 Camaro Parts
I have a complete set of NOS wheelwell trim, but I won't separate. $700.
Old 01-27-2009, 07:19 AM
Harris57 Harris57 is offline
PM sent
Old 01-27-2009, 03:49 PM
drdave69 drdave69 is offline
Contact JohnZ about how to block off the smog system.
I have a 290 horn that I disassembled, cleaned the internal coil and reassembled. It still did not function. I do not know what the date code is but I can check if you are interested.
Dave
1987 Grand National
Old 01-28-2009, 06:29 AM
Got the horns covered, thanks
Dave
Old 01-28-2009, 06:44 PM
427Guy 427Guy is offline
I noticed your post stating you have a set of NOS wheel well trim for a 1969 Camaro. Does the front or rear mouldings have a half moon cut out where the screw holes are?
Thanks
Old 01-29-2009, 08:32 PM
BARNFOUND YENKO BARNFOUND YENKO is offline
If you need a NOS dashpad for a non-air car EBAY listing ends tonite.
SURVIVOR 1970 PLYMOUTH SUPERBIRD
ORIGINAL 1969 CAMARO Z/28
1968 CAMARO RS/SS L89 CONVERTIBLE-1 OF 1
Old 01-30-2009, 02:38 AM
Not exactly sure what you are asking. All of the moldings I have simply have the holes punched. I have a couple of original pieces, and they have no half moon cutouts either...unless I don't understand what to look for...entirely possible!
Some are in the very old tan paper with blue print packaging and some is the newer GM white paper and clear plastic packaging.
