Old 05-16-2012, 12:35 PM
Default Tourque Thrust nuts
I just got a set of 15x7 Torque Thrust rims. What nuts should they be run with. Anyone got a name brand and part#. Just going on a stock Nova.
Thanks
Peter
Old 05-16-2012, 01:14 PM
Donnie's Avatar
Donnie Donnie is offline
Default Re: Tourque Thrust nuts
7/16 -20 with taper seat. for the new ones.
Lug Nut Seat Style; Conical seat - 60 degree
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 05-17-2012, 11:17 PM
Thanks.
How do you tell if they are new ones or old ones????
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 05-18-2012, 03:12 AM
Donnie's Avatar
Peter,
look on the back are they made in USA or china?
also you should be able to look at the seat on the rim and see if its tapered.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 05-18-2012, 05:10 PM
Thanks Donnie.
Rims say "made in the USA". When did that stop and China start making them???
Peter
Old 05-18-2012, 05:34 PM
Donnie's Avatar
American Racing was bought out and the new place moved production over there. not sure when it happened.
did you buy yours new or used?
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 05-20-2012, 12:56 PM
These were previously enjoyed.
Peter
Owen Simpson
Eric Simpson
Old 05-21-2012, 02:33 PM
92646 92646 is offline
Pete did you get your answer? I just bought a set of older 14x7 Torq-thrusts also and I am also looking for the right lug nuts. There is no taper in the hole and it looks like these had a washer before. If these had a shank would anybody have an idea how long the shank should be?
Old 05-21-2012, 02:49 PM
----All the shank does is center the wheel. If the shank is too long and sticks thru the back, obviously the wheel wont be tight. I dont think you will find too short a shank. Anything less than the thickness of the wheel thru the hole will probably work......Bill S
Old 05-21-2012, 05:44 PM
L72Chevelle L72Chevelle is offline
The new China made wheels have the 60 degree conical seat lugs and the older ones I have use a 3/4" shank with the washers. My older wheels are from around 1992-93 when they where reintroduced. Hope this helps you guys out, Phil.
