Old 08-28-2016, 02:16 PM
WILMASBOYL78's Avatar
Default 85 GMC Carb Project...
My Sunday morning project was to remove the QJ from our 85 GMC truck and send it to Dr. Eric for an overhaul. [long overdue]
Everything went smooth until I removed the kick-down cable connection...the plastic/rubber grommet fell apart. So while this won't impact the rebuild I will need to replace that little gizmo for the re-install.
Any ideas on where I can get one of these little parts...and can it be changed on the existing cable??
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 08-28-2016, 03:10 PM
earntaz earntaz is offline
Default Re: 85 GMC Carb Project...
If its a 700R4 I think you may need a new TV cable -- haven't seen any replacement clips ... TAZ [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 08-28-2016, 03:29 PM
VintageMusclecar's Avatar
http://www.rockauto.com/en/moreinfo....jsn=__GIX__3__
Old 08-28-2016, 03:40 PM
How cool is that..??? [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Thanks Eric [img]<<GRAEMLIN_URL>>/worship.gif[/img]
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 08-28-2016, 05:58 PM
There goes that cat meowing again ... great! Eric has this up his sleeve!! TAZ
Old 08-28-2016, 07:35 PM
bwag bwag is offline
Most of the franchise parts stores stock these in the Dorman - HELP section. I stocked these 20 years ago and the original clips are getting more brittle every day.
Old 10-02-2016, 08:14 PM
Update 10/2/16...carb arrived from Eric...installed today. As you would expect it functioned perfectly right out of the box! A couple of pumps and she fired right up...runs good.
I found one of those kick-down gizmos...so, that part was replaced...kick-down working fine.
Now for an oil change and a fresh set of plugs and we will be ready for opening weekend at camp. I did notice a little noise underneath....looks like it's time for some exhaust work [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Thanks Eric for a great job and all your help [img]<<GRAEMLIN_URL>>/worship.gif[/img]
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 12-14-2016, 10:10 PM
Well, as the cold weather moved in, I noticed the truck was harder to start. A call to the doctor solved the problem...an adjustment to the choke pull-off and an increase in the fast idle speed did the trick. She is now safely stored for the winter...no sleeping bag Sammy [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Thanks Eric...
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 12-15-2016, 02:30 PM
[img]<<GRAEMLIN_URL>>/flag.gif[/img]
