Old 04-15-2003, 09:32 PM
budnate's Avatar
budnate budnate is offline
Default Anyone run the Pertonix stuff??
Have any of you tried the Pertonix Ignitor ì2î ignition system with there Flame Thrower
Coil and there 7mm stock appearing Flame Thrower plug wires, on your cars????.
The Ignitor 2 is supposed to adjust dwell above 3 grand and really work well. So they say at there shop, I am wanting to upgrade the ign system but look close to stock, any feedback would be appreciated, I have all the trick Mallory stuff new in the box but just cant bring myself to install it in the car, just donít look right.
Thnx Bud.
Attachments - The Supercar Registry 38790-HEI3.jpg 38789-HEI2.jpg 38788-HEI1.jpg
Old 04-15-2003, 09:47 PM
Seattle Sam Seattle Sam is offline
Default Re: Anyone run the Pertonix stuff??
Bud,
Check the string under Pit Area called Pure Stock Drag Racing tips & tricks. It's discussed starting in about the third post...
https://www.yenko.net/ubbthreads/show...o=&fpart=1
-Sam [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 04-15-2003, 10:03 PM
Chevy454 Chevy454 is offline
There is some good reading in that link above.
Just make sure you get the "old" style, but I'm not for sure exactly which style the Pertronix II is...could I get some help here, Mo?
Old 04-15-2003, 10:14 PM
moparts moparts is offline
Not sure what the 2 is. The style we found to work best has the pickup that bolts to the underside of the rotor. The one that picks up off the lobes for the points had lots of starting problems.
20 foot 75 hp good time at the lake
Old 04-15-2003, 10:25 PM
budnate's Avatar
Not sure what to make of the posts on it, not much detail, sounds like it is better than points, but has broken twice with one guy, that is a pain had that happen years ago with another car a few times before we figured out they were selling us the wrong points, That does not work well when the car is broke on a nice summer night and you are not at home! I checked out the crane site, anyone try that kit yet??
Bud.
Old 04-15-2003, 10:38 PM
The Pertronix units are definitely easier to manage than points, but they do have their weak points. The Crane unit looks nice, but I haven't tried it...although I know someone that was thinking about it! Maybe he'll chime in...[img]/ubbthreads/images/graemlins/naughty.gif[/img]
Old 04-15-2003, 10:51 PM
budnate's Avatar
OK, lets talk spark!
Bud.
Old 04-15-2003, 11:03 PM
whitetop whitetop is offline
This topic was discused on a Mustang site several days ago. I think most people are overall happy with the Pertronix but there is enough of them conking out that most of even the die hard Pertronix people say to make sure your carry a spare set of points/screwdriver and feeler gauges in your trunk.
Old 12-29-2003, 05:21 PM
DaJudge DaJudge is offline
You may have already installed it by now. But M&H Wire fabricators has an electronic conversion that uses a single wire and you can use a stock coil or an upgraded one. It mounts completely under the OEM distibutor cap and it uses the existing distributor lead for a completely original appearance. I have used it on 4 cars and it works and performs flawlessly. Here's their web address www.breakerless.com
