Old 04-30-2003, 03:04 AM
musclcar musclcar is offline
Default crank case pan evac for the street
any thoughts or comments on running a pan evac on a very healthy sbc street motor.i'm running no pcv system and oil is soaking my 2 breathers on the valve covers.i was told that a pan-evac will help control /stop oil leaks and create lost h.p .i've gone completely over my motor and it's mechanically good.i'm just tired of the oil smell driping from the breathers onto the headers,due to not running a pcv system.will running a pan-evac be asking for more problems or am i ok with it [img]/ubbthreads/images/graemlins/[/img]
72 camaro ss 350 sbc 425hp old school day 2 build-up
Attachments - The Supercar Registry 39594-wheels up Malibu.jpg 39537-Ralph's burnout.jpg 39536-Ralph's smoker.jpg
Old 04-30-2003, 04:16 AM
Seattle Sam Seattle Sam is offline
Default Re: crank case pan evac for the street
It's an expensive way to solve the problem. I would make sure your valve covers have decent baffling around the breather holes, that might cure it.
-Sam
Old 04-30-2003, 04:25 AM
fpcopo fpcopo is offline
I agree with Sam. I'll bet those valve covers are open right down to the rockers. One easy way to get around this is to put riser tubes on the breathers like the oil fill tubes on pre '69 small blocks. also make sure the PCV is hooked up. It helps oil leaks from the main seals also.
Old 04-30-2003, 06:46 AM
Zman Zman is offline
I think evac-u-pan would be ok, and shouldn't cause any problems, unless you have to pass a smog test every year. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
with a standard PCV, the excess gases are sucked back into the intake, and re-burnt, with evac-u-pan, the gases are sucked right into the exhaust, where they might not be completely burt before being exhausted.
I had the same setup on a 340 Duster I had some yrs back.
I didn't have any problems, but afetr I sold the car, the guy I sold it to had to pass a smog test, and it failed.
I never did hear if he ever got it to pass, or what he had to do to get it to pass.
I simple PCV would be alot easier, and cheaper.
Dennis
69 Nova 355, M-21, 3.90 12 bolt
68 Chevelle SS 396 4 sp
Old 04-30-2003, 12:35 PM
ZL1mike ZL1mike is offline
I run vac u pan on my ZL1 motor and it seems fine but you can also run a puke can with a breather on top fastened to your rad support plumbed to the valve cover, I've used 2 of these cans on a buds BBC pro street/strip chevelle that made a mess of oil on the valve covers and that cured the problem, but he drives like this ( see pics )
Old 04-30-2003, 12:36 PM
another
Old 04-30-2003, 01:38 PM
Belair62 Belair62 is offline
Stefano....here is a lesson on keeping a car straight...pop quiz this weekend.
Old 04-30-2003, 05:14 PM
straight is good but how about hoping this car goes straight. 1.28 short time in the 60 ft and 9.50 @ 140 mph on the motor in gramas car. [img]/ubbthreads/images/graemlins/[/img]
