I need to ship a set of 455 Olds heads from Tulsa, OK 74055 to Oakley, CA 94561. The crate weighs 130 lbs and is 21x17x10"... Does anyone know who would be the cheapest possible way of sending these?? I would send these things by pack-mule if it was cheap enough.
https://t.me/pump_upp |
As funny as it might sound, Why not crate them seperate and send them by Greyhound. Unless they will take something that heavy.
IF YOU DON'T STAND BEHIND OUR TROOPS, PLEASE, FEEL FREE TO STAND IN FRONT OF THEM !!! |
I didn't think of that... I'll check Greyhounds rates. Thanks Jeff.
Jeff, thanks for the idea. I've been checking and found it to be cheaper to send them seperately anyhow
![]() ![]() Thanks. ![]() ![]() ![]()
Go buy some styro-foam and cut it in half and then hollow out the two halves and insert the head into the two peices. Get some long/thick Zip ties and secure the two halves together and then box them in a thick box. (use smaller thinner cardboard strips to lay under the Zip Ties so they dont dig into the foam and break it during shipping also) Would weigh less than wood and thus cheaper to ship. Oh if you go this route, Tape over any of the open ports to keep any foam from entering the ports.
said before these guys are cheap and good if they have hubs close to you and the other person they are hard to beat!
shipped several big items with them cheap! http://www.forwardair.com/ |
