Old 03-06-2008, 07:55 AM
Default Quick coil question
I have a good/working, dent free 293 coil. Am I correct in thinking this coil would have been used for a 69 L-78?.. If so, what gloss black should it be? It looks fairly glossy now, but could easily be painted satin.
69 El Camino
69 Nova
C7 Vette
Old 03-06-2008, 08:18 AM
Default Re: Quick coil question
A 293 is correct I believe for that motor. I have always seen them like a 60% gloss. More gloss than not. I would use it.
Old 03-06-2008, 08:52 AM
RamAirDave RamAirDave is offline
Ive always seen them to be fairly glossy. One thing to keep in mind is that the p# on the coil was for the coil/bracket assembly, not the coil itself.
http://www.camaros.net/forums/showpo...mp;postcount=8
TheMuscleCarGuys.com
Old 03-06-2008, 08:59 AM
John Brown's Avatar
More accurately the quote should be:
"The production assembly-line coil was supplied from Delco-Remy with the mounting bracket already attached, and the part number <u>in the assembly manual</u> is the number for that ASSEMBLY, not for the coil by itself."
The numbers on the coil <u>are</u> the last digits of the actual coil (by itself) part number.
John Brown
Old 03-06-2008, 02:55 PM
I think there were 3 different bracket styles. The 69 Z/28 took 298 which was embossed on the coil. That bracket kept the coil away from the chrome air cleaner.
Old 03-07-2008, 05:20 PM
Thanks guys. The coil has an original bracket which tilts back to keep it from hitting the air cleaner. It sounds like it's right for this engine. Done deal. It's fairly shiny, and on the engine. One more piece of the puzzle.
Just need the carb and smog back from resto, and the chassis is finished!!
