Old 05-18-2008, 01:52 PM
MotionJoe MotionJoe is offline
Default 11/1968 date 302 DZ engine
I have this DZ 302 engine with the date 11/68 with 1962 202 corvette heads . I searching for the correct heads for my DZ engine ? Can you tell me what is the proper application that I need ? to run with my DZ engine .? THZX mojo
Old 05-18-2008, 01:56 PM
Default Re: 11/1968 date 302 DZ engine
Note: 1962 corvette 202 heads are for sale too. good condition
Old 05-21-2008, 04:14 AM
427king 427king is offline
Yenko Paid Member
#186 double hump w accesory holes heads are used for 69 Z28s. #291s double hump w /no accesory holes for 68
Old 05-21-2008, 07:17 AM
92646 92646 is offline
The heads will have a hole on the side for the temp sensor like the later style also.
Old 05-23-2008, 11:20 AM
Thzx guys i have 186 heads C 4 0 date would that be correct ? here is vin# please decode this guys ?
vin# A 36990 VI010DZ on the pad 386 block. where the date
on the block? so i may try to find the right heads...Mojoe
Old 05-23-2008, 03:12 PM
V1010DZ=V is for flint 10 is the 10th month (October of 68)and 10 is for the day in October. DZ is the suffix code for a 302/Z28 motor. The block date is back by the distributor where the bell housing bolts to the block. A great source of info. is the CRG (Camaro Research Group). Type it in and join it.
Old 07-24-2008, 09:41 AM
What is the Vin on that block it was assembled the same day as the DZ I have down in the garage...
